Related system verilog Constraint random verificatio
I wrote below as per requiement that i have various constrints depends randomized value on particular signal.
Iam not getting expected output having constraints like this.
For me requirement is : If(GOOD_PKT)
if(WR)
addr==4;
else if (RD)
addr==5;
else(BAD_PKT)
//tras type should be idle
This way i need to make constraints.
for me now always BAD_PKT is getting generated and trans type is idle.
If you have any questions ask me on code.
program classex;
class pkt_ex;
typedef enum {BAD_PKT,GOOD_PKT} pkt_type_e;
typedef enum {RD,WR,IDLE} trans_type_e;
rand pkt_type_e pkt_type;
rand trans_type_e trans_type;
rand bit [7:0] addr;
constraint trans_bpc {(pkt_type==BAD_PKT)-> trans_type==IDLE;}
constraint addr_idlec {(trans_type==IDLE) β†’ addr==4; }
constraint trans_gpc {(pkt_type==GOOD_PKT)-> trans_type==(RD || WR);}
constraint addr_rdc {(trans_type==RD) β†’ addr==5; }
constraint addr_wrc {(trans_type==WR) β†’ addr==6; }
pkt_ex pkt_inst;
pkt_inst=new();
for(int i=0; i<5; i++) begin
 $display($time,"Inside repeat");
 pkt_inst.randomize();
 #2;
$display("%s %s %h \n",pkt_inst.pkt_type,pkt_inst.trans_type,pkt_inst.addr);
endprogram
Bharath
In your example, you are randomizing 5 times but only $display(ing) the last one. Since your pkt_type has a 50% chance of being bad, it’s possible that you will only $display a BAD_PKT. Additionally, if you simulate with the same random seed, you will always get the same result due to random stability.
If you $display each randomization result and run with different seeds, you should see a 50/50 mix of BAD_PKT and GOOD_PKT.
In reply to cgales:
I have update in code and modified the condtraints still iam getting result as PKT_TYPE=BAD_TYPE,trans_type=IDLE.
Output is:
vsim -sv_seed random classex_opr
Loading sv_std.std
Loading work.classex_opr(fast)
Sv_Seed = 108451649
run
Hello: pkt_type_0 = 1 ,trans_type_0 = 2 pkt_type = BAD_PKT ,trans_type = IDLE addr= 6
1
Simulation stop requested
Code:
program classex_opr;
typedef enum {GOOD_PKT,BAD_PKT} pkt_type_e;
typedef enum {WR,RD,IDLE} trans_type_e;
class pkt_cons;
randc pkt_type_e pkt_type;
randc trans_type_e trans_type;
constraint pkt_type_gdwc {(pkt_type==GOOD_PKT)-> trans_type== WR;}
constraint pkt_type_gdrd {(pkt_type==GOOD_PKT)-> trans_type== RD;}
constraint pkt_type_bdidle{(pkt_type==BAD_PKT)-> trans_type== IDLE;}
constraint trans_type_wrc {(trans_type==WR)-> addr==4;}
constraint trans_type_rdc{(trans_type==RD)-> addr==5;}
constraint trans_type_idlec {(trans_type==IDLE)-> addr==6;}
pkt_cons pkt1_inst;
pkt1_inst=new();
for(int i= 0; i<10;i++) begin
pkt1_inst.randomize();
$display("Hello: pkt_type_0 = %d ,trans_type_0 = %d pkt_type = %s ,trans_type = %s addr=%d",pkt1_inst.pkt_type,pkt1_inst.trans_type,pkt1_inst.pkt_type,pkt1_inst.trans_type,pkt1_inst.addr);
endprogram
In reply to bharath123:
The above code has some problem. for the same packet type you are defining two transaction types. Constraint solver will fail.
In reply to aming:
Just with little changes i am getting proper seq.
class pkt_cons;
constraint pkt_type_gdwc {(pkt_type==GOOD_PKT)-> trans_type inside {WR, RD};}
//constraint pkt_type_gdrd {(pkt_type==GOOD_PKT)-> trans_type== RD;}
pkt_cons pkt1_inst;
pkt1_inst=new();
endprogram
HHello: pkt_type_0 = 1 ,trans_type_0 = 2 pkt_type = BAD_PKT ,trans_type = IDLE addr= 6
Hello: pkt_type_0 = 0 ,trans_type_0 = 0 pkt_type = GOOD_PKT ,trans_type = WR addr= 4
Hello: pkt_type_0 = 0 ,trans_type_0 = 1 pkt_type = GOOD_PKT ,trans_type = RD addr= 5
In reply to Naven8:
You should note that randomize() is a function call with a return code that tells you if it is successful or not.
Your code should look something like:
if (!pkt1_inst.randomize()) $display("Randomize error!");
else $display("Hello: pkt_type_0 = %d ,trans_type_0 = %d pkt_type = %s ,trans_type = %s addr=%d",pkt1_inst.pkt_type,pkt1_inst.trans_type,pkt1_inst.pkt_type,pkt1_inst.trans_type,pkt1_inst.addr);
In reply to Naven8:
bharath123 :
please try ::
constraint pkt_type_gdwc {(pkt_type==GOOD_PKT)-> trans_type inside {RD,WR};}
For details of this issue you may refer to Dave comment
Assertion error, why? | Verification Academy
