I am not a very expert UVM user and I am running some trials with the register model.
In my testbench I have the following loop just to print the content of the register model:
my_regmodel.get_blocks(blks, UVM_HIER);
foreach (blks[b]) begin
$display("Block: %s (%s)", blks[b].get_name(), blks[b].get_full_name());
blks[b].get_registers(regs, UVM_HIER);
foreach (regs[r]) begin
$display("%s (%s) @0x%8h", regs[r].get_name(), regs[r].get_full_name(), regs[r].get_address());
regs[r].get_fields(fields);
foreach (fields[f]) begin
$display(" %s (%s): LSB=%0d, size=%0d, access=%s, reset_value=0x%0h, current_value=0x%0h",
fields[f].get_name(), fields[f].get_full_name(),
fields[f].get_lsb_pos(), fields[f].get_n_bits(), fields[f].get_access(),
fields[f].get_reset(), fields[f].get()
while (fields.size() > 0) void'(fields.pop_front()); // Empty the queue
while (regs.size() > 0) void'(regs.pop_front()); // Empty the queue
while (blks.size() > 0) void'(blks.pop_front()); // Empty the queue
This loop executed before any physical register access is performed.
I have the following question:
- why for all the registers the value I’m getting (get()) is different from the reset value and always 0? (of course there are a lot of registers with reset value different from 0).
Am I missing any operation to “synchronize” the model with the actual state of the circuit?
Thanks a lot in advance for any help.
Best regards,
Stefano
In reply to stefanotraferro:
Hi Stefano,
in which phase are you exercising your register model?
thanks for replying. This piece of code is in the body of my test sequence and it is executed after calling
super.body()
My test sequence is a derived class from a class which is, in turn, derived from uvm_reg_sequence:
- - my_parent_seq
[list]
- my_seq
[/list]
The code of my_parent_seq is simply:
class my_parent_seq extends uvm_reg_sequence;
`uvm_object_utils(my_parent_seq)
my_reg_model regmodel;
// Sequencer
my_uvc_sequencer p_sequencer;
function new(string name = "");
super.new(name);
set_automatic_phase_objection(1);
endfunction: new
virtual task body();
assert($cast(p_sequencer, m_sequencer));
assert($cast(regmodel, p_sequencer.cfg.regmodel));
endtask: body
endclass: my_parent_seq
What I’ve noticed is that the values returned by get() are updated to the actual value only after a physical read, which is not would I would expect.
Here’s a practical example:
- I have a register with default (reset) value 0x03fc;
- the two LSBs are associated to a field;
- I change the value of that field to 3:
temp_reg = my_regmodel.reg_blk.get_reg_by_name("my_region.my_reg");
temp_field = temp_reg.get_field_by_name("my_field"); temp_field.set( 3 );
temp_reg.update(status); assert(status == UVM_IS_OK);
At this point, I am expecting the generated transaction to write 0x03ff to the register, instead it writes 0x0003.
The only way to get 0x03ff is to read the register first.
Another note: the UVM test reg_all passes I guess just for the reason that the first set of accesses is a read of the complete register map to perform the reset value sub-test.
Is all of this expected?
Am I really supposed to physically read the complete register map to have a consistent model?
Thanks in advance for any help.
After constructing a sequence with sequence items are data fields are initialized to its inital values. If you want to see the reste values you have to execute a reset sequence first. The UVM library provides you such a sequence (uvm_reg_hw_reset_seq).
Thanks for your reply.
So, since uvm_reg_hw_reset_seq performs physical register accesses, the initialization of the model is done through actual register access as I was guessing, isn’t it?
Am I missing something?
No it is not the initializaion it is setting the reg values to its reset value and it goes through accessing the registers physically.
Thanks for the reply.
I guess I’ve found the solution: the .reset() method must be invoked to synchronize the mirrored values with the reset values:
my_regmodel.reset()
This method is called by the sequences available in the UVM library, but must be explicitly called in case of a custom sequence.
