Register model initial values
Hi,
thanks for replying. This piece of code is in the body of my test sequence and it is executed after calling
super.body()
My test sequence is a derived class from a class which is, in turn, derived from uvm_reg_sequence:
  • uvm_reg_sequence
  • - my_parent_seq
    [list]
    - my_seq
    [/list]
The code of my_parent_seq is simply:
class my_parent_seq extends uvm_reg_sequence;
  `uvm_object_utils(my_parent_seq)
  my_reg_model regmodel;
  // Sequencer
  my_uvc_sequencer p_sequencer;
  function new(string name = "");
    super.new(name);
    set_automatic_phase_objection(1);
  endfunction: new
  virtual task body();
    assert($cast(p_sequencer, m_sequencer));
    assert($cast(regmodel, p_sequencer.cfg.regmodel));
  endtask: body
endclass: my_parent_seq
What I’ve noticed is that the values returned by get() are updated to the actual value only after a physical read, which is not would I would expect.
Here’s a practical example:
  • I have a register with default (reset) value 0x03fc;
  • the two LSBs are associated to a field;
  • I change the value of that field to 3:
temp_reg = my_regmodel.reg_blk.get_reg_by_name("my_region.my_reg");
temp_field = temp_reg.get_field_by_name("my_field"); temp_field.set( 3 );
temp_reg.update(status); assert(status == UVM_IS_OK);
At this point, I am expecting the generated transaction to write 0x03ff to the register, instead it writes 0x0003.
The only way to get 0x03ff is to read the register first.
Another note: the UVM test reg_all passes I guess just for the reason that the first set of accesses is a read of the complete register map to perform the reset value sub-test.
Is all of this expected?
Am I really supposed to physically read the complete register map to have a consistent model?
Thanks in advance for any help.
