Hi All,
Consider the following code snippet
// Called from body() task with last arg. as config_h.reg_block.XMT_WR.get_name()
task write_data_axi(input integer my_addr, input bit [31:0] data_in, string name);
uvm_reg reg_h;
`uvm_info("write_dat_axi",$sformatf("Called with i/p arg. as %0s",name),UVM_LOW)
// Assume that config_h.reg_block is non-null
reg_h = config_h.reg_block.get_reg_by_name(name);
if( reg_h != null ) begin
if(!reg_h.predict(data_in))
`uvm_error(get_name(),$sformatf("Prediction Unsucessful"))
`uvm_fatal(get_type_name(),$sformatf("Unable to find register: %0s",name))
The output when write_data_axi is called
UVM_INFO … [write_dat_axi] Called with i/p arg. as XMT_WR
UVM_FATAL … [b2b_isr_seq] Unable to find register: XMT_WR
It seems that API ‘get_reg_by_name’ returns null due to which the UVM_FATAL msg is observed
If I change the code to
if( config_h.reg_block.get_reg_by_name(name) != null ) begin
if(!reg_h.predict(data_in)) `uvm_error(get_name(),$sformatf("Prediction Unsucessful"))
I don’t encounter the UVM_FATAL message.
Any suggestions on what’s the issue with the 1st code ?
Thanks in Advance
