Reference signal name from parent module
I want to reference the name of a signal that is on the input of my module.
For example, currently I write this.
    sigref_checker
    #(.reltol(0.0),
      .abstol(0.1),
      .startTime (111111ps),
      .stopTime(911111ps),
      ._signal("OUT1"),
      ._ref_signal("OUT2")
      chk1 (
      .signal(OUT1),
      .ref_signal(OUT2),
      .enable_signal(1'b1)
It would be nice if “._signal” and “._ref_signal” could be inferred internally in the chk1 module, so that my chk1 module prints:
top.chk1.sig_ref_chk FAIL: OUT1 < OUT2-tol (1.666667 < 1.876363)
Instead of:
top.chk1.sig_ref_chk FAIL: signal < ref_signal-tol (1.666667 < 1.876363)
I tried using macros inside the module, but I was not able to reference the parent signal name from within the module
In reply to ricardosilvestre:
0
It is possible to do this creating a C function using SystemVerilog’s VPI.
int getParentName(char *user data) {
    vpiHandle system_h, arg_itr, in_h, , out_h, parent_handle;
    s_vpi_value out_s;
   // all this code just to get a handle to the function's argument
   // and without proper error checking
   sys_h = vpi_handle(vpiSysTfCall, NULL);
   arg_itr = vpi_iterate(vpiArgument, sys_h);
   in_h = vpi_scan(arg_itr);
   out_h = vpi_scan(arg_itr);
   // now get its parent net
   parent_h = vpi_get(vpiHighConn, in_h);
   // return the name of the net
   out_s.format = vpiStringVal;
   out_s.str = vpi_get_str(vpiName,parent_h);
   vpi_put_value(out_h,&out_s);
Inside your checker module you would call $getParentName(signal,name);
But it might be just easier to create a macro that instantiates your checker module
`define sigref_checker_inst(R,A,START,STOP,SIGNAL,REF) \
#(.reltol(R), \
  .abstol(A),\
  .startTime (START),\
  .stopTime(STOP),\
  ._signal(`"SIGNAL`"),\
  ._ref_signal(`"REF`")\
  chk1 (\
  .signal(SIGNAL),\
  .ref_signal(REF),\
  .enable_signal(1'b1)\
thank you so much for the answer!! it is what I was expecting!, Could you please tell me where and how to place the VPI function in my code? I got a compilation error if I place it in the SV file
C code needs to be in a separate file. How you compile C code into your simulation is tool specific.
This Mentor/Siemens EDA sponsored public forum is not for discussing tool specific usage or issues. Please read your tool’s user manual or contact your tool vendor directly for support.
