$readmemh -- is there something better?
Regarding systemverilog file IO, $readmemh has been around a long time. Is there something better?
I would like to read the contents of a file into a queue, rather than a memory. I gave this (below) a shot, but now I have a queue of strings. The string values look like this: “0x1234”. What is the best way to convert “0x1234” to something that I can store in logic [15:0] hex_reg?
I am asking because I cannot change the format of the file that I am receiving. Perhaps I should pre-process the file using something like python, and then just use $readmemh?
Thanks!
Aaron
typedef string file_lines_queue[$];
 function automatic file_lines_queue get_file_lines(string file_name);
      int fd;
      string line;
      file_lines_queue ret;
      fd = $fopen(file_name, "r");
      if (fd)  begin
          $display("File %s was opened successfully", file_name);
          while (!$feof(fd)) begin
              $fgets(line, fd);
              ret.push_back(line);
              // $display ("Line: %s", line);
      end else begin
          $display("File %s was NOT opened successfully", file_name);
      $fclose(fd);
      return ret;
  endfunction : get_file_lines
In reply to aale:
Use $fscanf instead of $fgets
typedef bit [15:0] uint16_t;
typedef uint16_t uint16q_t[$];
function automatic uint16q_t get_file_lines(string file_name);
      int fd;
      uint16_t value;
      if (fd)  begin
          while ($fscanf(fd,"%x",value))
              get_file_lines.push_back(value);
      end else begin
      $fclose(fd);
This almost worked. With $fscanf() as a while loop argument, the while loop hung. This tweak worked…
  uint16q_t gain_offset_queue;
      int fd;
      uint16_t value;
      uint16q_t ret;
      int line_num = 0;
      if (fd)  begin
              $fscanf(fd, "%x", value);
              ret.push_back(value);
              if (line_num < 10) begin
                $display ("Line[%04d]: 0x%04X", line_num++, ret[ret.size()-1]);
      end else begin
      $fclose(fd);
      return ret;
Any idea why $fscanf as a while loop argument didn’t work?
Another interesting side note. Check out the $dsiplay and note the capital X in 0x%04X. The output looks like this:
File ../../tb/raw_proc/c_model/output/grid.mem was opened successfully
Line[0000]: 0x00ca
Line[0001]: 0x00ac
Line[0002]: 0x00dc
Line[0003]: 0x0108
Line[0004]: 0x010a
Line[0005]: 0x0136
Line[0006]: 0x015e
Line[0007]: 0x0174
Line[0008]: 0x0146
Line[0009]: 0x015c
Why are the a-f characters not capitalized? I am using questa 10.7c.
Thanks!
Aaron
In reply to aale:
I see that my post has the no formatting. In the future, how can I keep the verilog formatted so that it is easier to read?
In reply to aale:
Code Tags I have added them for you.
Without all the code and a text file we can’t debug your problem.
SystemVerilog format specifiers are case insensitive; the output is always in lowercase except for certain conditions with unknowns.
Forgive the newbie questions. Okay, code tags are awesome. Got it. Next, in order to send you a complete code snippet, can I attach a file, or what do you recommend?
Tahnks!
Aaron
In reply to aale:
