Dear team,
Kindly advise a few methods to generate random numbers within a specified range with examples
Dear team,
In reply to ArjunNag:
I’ll give you one way and you can explain why you need “a few”
class A;
randc int number; // randc means do not repeat until all solutions produced
int low_bound = 1, high_bound = 10;
constraint c_range { number inside {[low_bound:high_bound]}; }
A a_h = new;
initial repeat (100) begin
void'(a_h.randomize());
$display(a_h.number);
Dear Dave,
below is the outcome of the above code…
kindly advise next steps
run: 15.20-s038: (c) Copyright 1995-2017 Cadence Design Systems, Inc.
Top level design units:
top
ncelab: *W,DSEMEL: This SystemVerilog design will be simulated as per IEEE 1800-2009 SystemVerilog simulation semantics. Use -disable_sem2009 option for turning off SV 2009 simulation semantics.
Loading snapshot worklib.top:sv … Done
SVSEED default: 1
ncsim: *W,DSEM2009: This SystemVerilog design is simulated as per IEEE 1800-2009 SystemVerilog simulation semantics. Use -disable_sem2009 option for turning off SV 2009 simulation semantics.
ncsim> source /incisiv/15.20/tools/inca/files/ncsimrc
ncsim> run
0
0
0
0
0
0
0
ncsim: *W,RNQUIE: Simulation is complete.
ncsim> exit
Done
I had a small typo, call **a_h.**randomize()
class a;
randc int num;
int rang1=100;
int rang2=200;
constraint c{ num inside {[rang1:rang2]};}
a handle;
initial
handle =new();
repeat(10)
handle.randomize();
$display("num=%d",handle.num);
