RAL: uvm_reg_map base address does not work
Hello,
I’m trying to set a base address of the default_map different from 0 using the the create_map function as the following:
     this.default_map = create_map("", 32'h00010000, 4, UVM_LITTLE_ENDIAN, 1);
the regmodel still consider the base address as 0, could you please tell me why the above base address setting doesn’t work?
thanks,
In reply to Mohamed_TN:
How do you specify the offset in the add_reg method?
I don’t consider the base address (truncated address).
the following function worked well:
    regmodel.default_map.set_base_addr(32'h00010000);
it seems there is a limitation in the create_map function !
