So this is less of a question and more of an FYI to anyone else who has this error.
Compiling completed successfully, but during vopt I received this error (on the line “Sending peripheral READ transaction”):
** Error: <path/file_name>: Questa has encountered an unexpected internal error: ../../src/vlog/vgencode.c(207) <!cur_gen_stack_info || cur_gen_stack_info==stack_info>. Please contact Questa support…
** Error: (vopt-2064) Compiler back-end code generation process terminated with code 2.
The code is:
`define uvm_info_type_name(MSG,VERBOSITY) `uvm_info(get_type_name().toupper(), MSG, VERBOSITY)
class seq_base extends uvm_sequence #(item_base, item_base);
`uvm_object_utils(seq_base)
global_cfg global_cfg_h;
bus_item bus_item_h; // extends item_base
bus_item rsp_item_h; // extends item_base
function new(string name = "seq_base");
super.new(name);
if (!uvm_config_db #(global_cfg)::get(get_sequencer(), get_type_name(), "global_cfg", global_cfg_h))
`uvm_fatal_type_name("Cannot get() global_cfg from uvm_config_db. Have you set() it?")
endfunction : new
task body();
`uvm_error_type_name("You forgot to override the base sequence!")
endtask : body
endclass : seq_base
class slave_seq extends seq_base;
`uvm_object_utils(slave_seq)
function new(string name = "slave_seq");
super.new(name);
endfunction // new
task body();
`uvm_info_type_name("Starting sequence...", UVM_LOW)
forever begin : send_trans
wait(global_cfg_h.reset_isasserted == 1'b0);
if (global_cfg_h.test_done == 1'b0) begin
`uvm_info_type_name("Sending peripheral READ transaction", UVM_LOW)
`uvm_do_with(bus_item_h, { trans_type == READ; })
get_response(rsp);
$cast(rsp_item_h, rsp);
rsp_item_h.print();
if (global_cfg_h.test_done == 1'b1)
break;
#1ns; // delay so forever doesn't hang
begin : check_global_cfg
wait(global_cfg_h.test_done == 1'b1);
#100ns; // give the driver a chance to return the sequence-in-progress nicely
disable send_trans;
join_any
`uvm_info_type_name("Sequence completed!", UVM_LOW)
endtask : body
endclass : slave_seq
I found that by changing the macro to be:
`define uvm_info_type_name(MSG,VERBOSITY) `uvm_info(type_name.toupper(), MSG, VERBOSITY)
that the error goes away!
If anyone can explain why, it would be much appreciated!
