I have multiple dynamic req/ack signal pairs in my simulation. For example, 0 to 10 req/ack signals available. At run time from class configuration field I can know that what number of req/ack signals are present for that simulation.
I want to write a property with argument and want to create a loop for all req/ack signals in simulations.
property req_with_ack(logic req, logic ack);
@(posedge clk) disable iff (!reset)
$rose(req) |-> $rose(ack) > 0));
Remember I can not use generate block as I dont have req/ack number initially in the interface where the property is written.
For example if there are 2 req/ack signals in the simulation then dynamically I want to create below properties without using generate block,
1)
$rose(req[0]) |-> $rose(ack[0]) > 0));
$rose(req[1]) |-> $rose(ack[1]) > 0));
Is that possible?
Thank you.
user49
April 7, 2018, 8:32pm
2
In reply to megamind :
The issue here is that assertions need to be setup at elaboration time. Consider using the task approach as described in my verification Horizons paper
VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
Below is an example that demonstrates the concepts of your case. Debugging is a bit difficult, but you can add more debug info is needed.
timeunit 1ns; timeprecision 100ps;
bit clk, reset=1'b1;
logic[0:3] req, ack, req_past, ack_past;
bit[1:0] size=3;
event e0, e;
default clocking @(posedge clk);
endclocking
initial forever #10 clk=!clk;
/* property req_with_ack(logic req, logic ack);
$rose(req) |-> $rose(ack);
always @(posedge clk) begin
for (int i=0; i<size; i++) begin // Bad handle or reference.
ap_i: assert property(req_with_ack(req[i], ack[i]));
end */
always_ff @(posedge clk) begin
req_past <= req;
ack_past <= ack;
task automatic t_req_with_ack(logic req, logic ack);
if (!reset) return;
if(req && !req_past) begin : rose
-> e0;
@(posedge clk);
a_reqack: assert (ack && !ack_past);
-> e;
return;
end : rose
else return; // optional here
t_req_with_ack(req[i], ack[i]);
join_none
repeat(200) begin
@(posedge clk); #2;
if (!randomize(req, ack, size) with
{ size >1 ; })
`uvm_error("MYERR", "This is a randomize error");
$stop;
// simulation
** Error: Assertion error.
# Time: 410 ns Scope: top.t_req_with_ack.rose.a_reqack File: C:/ben_play/./reqack_dyn.sv Line: 31
# ** Error: Assertion error.
# Time: 1090 ns Scope: top.t_req_with_ack.rose.a_reqack File: C:/ben_play/./reqack_dyn.sv Line: 31
# Time: 1730 ns Scope: top.t_req_with_ack.rose.a_reqack File: C:/ben_play/./reqack_dyn.sv Line: 31
See Paper: VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
In reply to ben@SystemVerilog.us :
Thank you, this helped to understand.
