Problem while using `ifdef..`elsif..`else
How to implement OR operation using defines?
for example,(snippet)
→ define DEF_1 define DEF_2
ifdef DEF_1 ifdef DEF_2
//Block of code that needs to be executed
endif endif
in the above case it behaves like an AND operation.i.e,if both DEF_1 and DEF_2 are defined then only the block will get executed.But I want to implement OR operation which means if either DEF_1 or DEF_2 are defined,then only the block should get executed.How can I do that?
SATYA
In reply to SATYA369:
`ifdef DEF_1
  `define DEF_1OR2
`elsif DEF_2
  `define DEF_1OR2
`endif
`ifdef DEF_1OR2
`endif
Thanks dave
Regards
SATYA
