Port mismatch while connect interface and dut
Hello I was trying to connect a DUT to interface and used logic type in interface and connected them to DUT signals. DUT signals inside DUT are declared as wire. Compilation is giving error
Error-[PCTM] Port connection type mismatch
The following expression is illegally connected to port “pkt_tx_data” of
module “xge_mac”, instance “dut”. The type of the port does not match that
of the port connect.
Code is as below. I have connected module port declared as wire to logic types declared in interface before but did not face this issue before.
xge_mac dut(
	            // Outputs
	            .pkt_rx_avail               (i_pkt_rx_interface.pkt_rx_avail),
	            .pkt_rx_data                (i_pkt_rx_interface.pkt_rx_data[63:0]),
	            .pkt_rx_eop                 (i_pkt_rx_interface.pkt_rx_eop),
	            .pkt_rx_err                 (i_pkt_rx_interface.pkt_rx_err),
	            .pkt_rx_mod                 (i_pkt_rx_interface.pkt_rx_mod[2:0]),
	            .pkt_rx_sop                 (i_pkt_rx_interface.pkt_rx_sop),
	            .pkt_rx_val                 (i_pkt_rx_interface.pkt_rx_val),
	            .pkt_tx_full                (i_pkt_tx_interface.pkt_tx_full),
	            .wb_ack_o                   (i_wishbone_interface.wb_ack_o),
	            .wb_dat_o                   (i_wishbone_interface.wb_dat_o[31:0]),
	            .wb_int_o                   (i_wishbone_interface.wb_int_o),
	            .xgmii_txc                  (i_xgmii_tx_interface.xgmii_txc[7:0]),
	            .xgmii_txd                  (i_xgmii_tx_interface.xgmii_txd[63:0]),
	            // Inputs
	            .clk_156m25                 (clk_156m25),
	            .clk_xgmii_rx               (clk_xgmii_rx),
	            .clk_xgmii_tx               (clk_xgmii_tx),
	            .pkt_rx_ren                 (i_pkt_rx_interface.pkt_rx_ren),
	            .pkt_tx_data                (i_pkt_tx_interface.pkt_tx_data[63:0]),
	            .pkt_tx_eop                 (i_pkt_tx_interface.pkt_tx_eop),
	            .pkt_tx_mod                 (i_pkt_tx_interface.pkt_tx_mod[2:0]),
	            .pkt_tx_sop                 (i_pkt_tx_interface.pkt_tx_sop),
	            .pkt_tx_val                 (i_pkt_tx_interface.pkt_tx_val),
	            .reset_156m25_n             (reset_156m25_n),
	            .reset_xgmii_rx_n           (reset_xgmii_rx_n),
	            .reset_xgmii_tx_n           (reset_xgmii_tx_n),
	            .wb_adr_i                   (i_wishbone_interface.wb_adr_i[7:0]),
	            .wb_clk_i                   (wb_clk_i),
	            .wb_cyc_i                   (i_wishbone_interface.wb_cyc_i),
	            .wb_dat_i                   (i_wishbone_interface.wb_dat_i[31:0]),
	            .wb_rst_i                   (wb_rst_i),
	            .wb_stb_i                   (i_wishbone_interface.wb_stb_i),
	            .wb_we_i                    (i_wishbone_interface.wb_we_i),
	            .xgmii_rxc                  (i_xgmii_rx_interface.xgmii_rxc[7:0]),
	            .xgmii_rxd                  (i_xgmii_rx_interface.xgmii_rxd[63:0]));
Interface is declared as below. Others interface follows same convention.
interface pkt_tx_interface(input bit clk_156m25, input logic reset_156m25_n);
	logic pkt_tx_data[63:0];
	logic pkt_tx_val;
	logic pkt_tx_sop;
	logic pkt_tx_eop;
	logic pkt_tx_mod[2:0];
	logic pkt_tx_full;
endinterface
In reply to aashishs2603:
Found the issue problem is in declaring pkt_tx_data[63:0] as opposed to [63:0] pkt_tx_data. I am confused why would error prompt say type mismatch. Should be something like size mismatch
They have have the same size—64 bits. But one is an unpacked array of 64 1-bit elements, and the other is 1 64-bit wide packed array.
Thanks Dave, makes sense
