confused in using ref function? what is the benefit of using ref in function arguments? give an example how variable values will effect with & without using ref in function arguments
In a function, the only benefit is performance in passing large data structures like an array instead of using an inout.
In a task that consumes time, a ref can be used instead of an inout to capture value changes that occur while the task is active. Remember that an inout argument is copied into the task when it is called, and copied out when the task returns. Here is an example that I did not try, so excuse the typos.
logic A,B;
task automatic mytask(inout logic arg1, ref logic arg2);
#0 $display("%m %t arg1 %b arg2 %b",$time,arg1,arg2);
// actual arguments have been set to 0
#5 $display("%m %t arg1 %b arg2 %b",$time,arg1,arg2);
#0 arg1 = 1; arg2 = 1;
initial #1 mytask(A,B);
A = 'z; B ='z;
#2 A = 0; B = 0; // after call
// arguments have been set to 1
#5 $display("%m %t A %b B %b",$time,A ,B);
See the difference between the inout and pass by ref arguments.
Note that a class variable is a reference to a class handle already, so passing a class variable by reference rarely has any benefit.
thank you dave_59…
In reply to kulwantsingh:
Hello Dave,
I tried the following below process but still I was getting the same error i.e. “invalid ref argument usage because actual argument is not a variable”
Extern Task Instance:
extern virtual task d_c_p(int j, ref rst, ref clk, ref dbn);
Task Declaration:
Task Usage: Note, this task is called multiple times recursively
logic dbn_l[MAX_LIMIT];
d_c_p(j, r_vif.rst, r_vif.clk, dbn_l[j]);
Am I making any silly mistake ? Kindly provide your comments.
Regards,
Desperado
In reply to desperadorocks:
Thanks Dave…
Got your response in another post.
FI…
https://verificationacademy.com/forums/systemverilog/can-array-element-be-passed-ref-argument-task
Desperado
Works for me in Questa.
class C;
bit a[10];
extern virtual task p(ref bit c);
endclass : C
task C::p(ref bit c);
#10;
endtask : p
C c =new;
c.p(c.a[1]);
endmodule : top
Can you show me a small, complete, self-contained example?
Hello Dave,
Please find the example given below.
class fruit;
logic dbn_l[2];
extern virtual task apple(ref logic fruit_type);
endclass: fruit
task fruit::apple(ref logic fruit_type);
#10 $display("Inside Apple. Value of fruit_type = %0d\n", fruit_type);
endtask: apple
fruit fr = new();
fr.dbn_l[0] = 1;
fr.dbn_l[1] = 1;
fr.apple(fr.dbn_l[1]);
endmodule: top
And below is the error message when I ran in Incisive. Its working fine in VCS.
irun: 13.10-e280: (c) Copyright 1995-2014 Cadence Design Systems, Inc.
file: task_ref.sv
ncvlog: *E,BADRFA (task_ref.sv,20|17): invalid ref argument usage because actual argument is not a variable. [SystemVerilog].
module worklib.top:sv
errors: 1, warnings: 0
ncvlog: *F,NOTOPL: no top-level unit found, must have recursive instances.
irun: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 2).
I suppose its a tool issue. Will check with the corresponding CAE team.
Had a doubt on the UVM register and posted the same in the below link and awaiting your valuable comments.
Desperado !!
