I have a top level module where Im using a parameter value of 28. In the first instantiation when I use the parameter value it takes effect although Im using a different number (14 in this case) within the module it gets overriden to 28 which is what I expect but when i go one level down further and use the same parameter but Im using a typedef in this case I see 14 instead of 28 is this expected?.
Here is the code
top module:
module top (
peci #(
.XXTOR_PECI_DATA_BYTES_LEN(28)
First level instantiation:
module pcei (
parameter XXTOR_PECI_DATA_BYTES_LEN = 14;
parameter XXTOR_PECI_DATA_BITS_LEN = 8*XXTOR_PECI_DATA_BYTES_LEN;
logic [XXTOR_PECI_DATA_BITS_LEN -1:0] TxBuffer;
In this case I see TxBuffer is 224 bits wide
One level down:
parameter XXTOR_PECI_DATA_BYTES_LEN = 14 ;
typedef reg [XXTOR_PECI_DATA_BITS_LEN -1:0] t_peci_xtor_tx_buffer ;
I see t_peci_xtor_tx_buffer is 112 bits (8*14) rather than 222 bits wide. Is it because Im using a typedef here?.
Sid
In reply to Sid85:
Since you did not show enough code, I’m guessing you need pass the override down the hierarchy. The override at the first level is not recursive.
My question is typedef preventing the override from happening at the lower level module. Im using the same parameter value in the lower level as the first level (14) but the only difference is typedef so Im wondering if this is a system verilog restriction on parameter override for typedef?.
SOrry Im unable to share a lot of code.
Sid
In reply to Sid85:
The use of a parameter in a typedef, or in any other construct should not prevent an override.
Did you override the parameter in the second level instantiation?
module top (
peci #(
module pcei (
// code you did not show
second_level_module #(.XXTOR_PECI_DATA_BYTES_LEN(XXTOR_PECI_DATA_BYTES_LEN)))...
module second_level_module(...);
// end code you did not show
Thanks. I have the parameter set to 14 in the second level but at the top level it is set to 28 so it should override my setting in the second level instantiation but it doesnt for some reason.
In reply to Sid85:
You haven’t answered my question: Did you override the parameter in the second level instantiation? Meaning there needs to be two overrides as I showed you in my example.
