Need SV Assertion to trigger once per signal edge
Hello,
I am trying to write an assertion using SVA for the following scenario:
When the signal called ‘valid’ goes HIGH, it results in another signal called ‘alert’ going HIGH 2 or more clock cycles later. The alert signal is eventually cleared by another part of the HW. For each rising edge of valid, I expect to see a rising edge for alert. The assertion I initially wrote was this:
property valid_alert_p(valid, alert);
  @(posedge clk) valid |-> ##[2:$] $rose(alert);
This works in most scenarios. However, when a situation arises where alert has not yet been cleared and I see two consecutive rising edges for valid, and then alert is eventually cleared, the very next rising edge on alert causes the assertions for both of those consecutive valid triggers to pass. What I instead want to see is a separate assertion for each pair of valid and alert. I have attached a waveform to demonstrate the problem:
Any help would be appreciated.
Thank you!
In reply to sidmodi:
I address this topic of Uniqueness in attempted threads in my SVA Handbook Basically, need to assure that each started assertion from start to completion is unique; this means that if multiple assertions are started at different cycles because of a successful antecedent, a successful consequent should not terminate all those assertions. Below is a link to those pages from my book that explains the solution.
If you have any questions after you read section 10.26 Uniqueness in attempted threads – the FIFO, let me know.
    Browse all content in Verification Academy: Articles, Cookbooks, Resources, Sessions, and Tracks
  2. SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
Thank you! I was able to follow section 10.26 and achieved what I needed to.
