Hi Folks
To verify Memory which is having two different write ports port_a and port_b clocked with clk_a and clk_b writes and do we need seperate systemverilog interfaces to drive pins ??
Jayesh J Parmar
Hi Folks
Jayesh J Parmar
In reply to Jayesh Parmar:
The most flexible solution would be to create an interface which connects to a single port. You can then instantiate this interface multiple times to match the number of ports in the memory.
In reply to cgales:
Thank you for your response !
With two different clocks created and passed to interface would be also fine solution as below.
Please give your comments whether for large memory environment this would be right approach.
interface ram_if(input bit a_clk,input bit b_clk);
logic rst;
//logic a_clk;
logic a_wr; // pulse a 1 to write and 0 reads
logic [`RAM_ADDR_WIDTH-1:0] a_addr;
logic [`RAM_DATA_WIDTH-1:0] a_data_in;
logic [`RAM_DATA_WIDTH-1:0] a_data_out;
//logic b_clk;
logic b_wr; // pulse a 1 to write and 0 reads
logic [`RAM_ADDR_WIDTH-1:0] b_addr;
logic [`RAM_DATA_WIDTH-1:0] b_data_in;
logic [`RAM_DATA_WIDTH-1:0] b_data_out;
clocking drv_cb1@(posedge a_clk );
default input #1ns output #1ns;
//all input will be -->output w.r.t TB
output a_wr,a_addr,a_data_in,rst;
input a_data_out;
endclocking
clocking drv_cb2 @(posedge b_clk);
output b_wr,b_addr,b_data_in,rst;
input b_data_out;
endclocking
endinterface
Regards
Jayesh J Parmar
As I stated in my first response, the best solution for scalability is to have a single port in the interface, and instantiate the interface the required number of times to match the design.
You should also parameterize the interface with the ADDR_WIDTH and DATA_WIDTH instead of using `defines. This ensures that your interface is compatible with the remainder of your testbench.
In reply to cgales:
Thanks for your valuable comments and will fix it using above methods.
Regards
Jayesh J
