Magic square on system verilog
I am trying to write a program where the rows, columns, and diag of the matrix should be equal to 15. when i enabled the first contraint it seems i am getting some random value instead of 15 any idea why?
// Code your design here
class magicsquare;
  rand bit [7:0] a [0:2][0:2];
  int i,j,k;
  constraint c1 {foreach (a[i,j])
    if (j==0) {a[i].sum() ==8'd15; } }
  function void display ();
                 $display ("The value of array is %p",a);
module test;
  magicsquare m1;
    m1=new ();
    m1.randomize();
    m1.display();
In reply to rag123:
See Constraint Randomization | Verification Academy
I modified the code, but i dont see rows 2 and 3 is equal to 15.
class magicsquare;
  rand bit [7:0] b [0:2][0:2];
  int i,j,k;
  if (i==0)  {a.sum() with (int'(item)) ==8'd15; } }
      constraint c2 {foreach (a[i,j])
        if (i==1){ a.sum() with (int'(item)) == 8'd15 ;}}
   //   constraint c2 {foreach (a[i,j])
     //   if (i==0) {a.sum() with (int'(item)) ==8'd15; } }
module test;
  magicsquare m1;
    m1=new();
    m1.randomize();
    m1.display();
Expected output:
2   7   6
  9   5   1
  4   3   8
In reply to rag123:
I believe you want
constraint c1 {foreach (a[i,])
 if (i==0||i==1){ a[i].sum() with (int'(item)) == 8'd15 ;}
class magicsquare;
int i,j,k;
if (i==0||i==1||i==2){ a[i].sum() with (int'(item)) == 8'd15 ;}}
    if (j==0||j==1||j==2){ a[j].sum() with (int'(item)) == 8'd15 ;}}
 //     constraint c3 {foreach (a[i!=j])
 //     { a[i!=j].sum() with (int'(item)) == 8'd15 ;}}
$display (“The value of array is %p”,a);
program test;
magicsquare m1;
m1=new();
m1.randomize();
m1.display();
endprogram
The value of array is ‘{’{'h8, 'h1, 'h6}, '{'h3, 'h5, 'h7}, '{'hf, 'h0, 'h0}}
Thanks Dave. This satisfies the row constraints, but some how the column constraint is not satisfied. Also i need the sum of elements 00,11,22 to be 15 as well. I tried something like this, but it doesnt seem to compile.
constraint c {
  a.sum() with (item.index(1)==0 ? item : 0) == 15;//row0
  a.sum() with (item.index(1)==1 ? item : 0) == 15;//row1
  a.sum() with (item.index(1)==2 ? item : 0) == 15;//row2
  a.sum() with (item.index(2)==0 ? item : 0) == 15;//col0
  a.sum() with (item.index(2)==1 ? item : 0) == 15;//col1
  a.sum() with (item.index(2)==2 ? item : 0) == 15;//col2
  a.sum() with (item.index(1) == item.index(2) ? item : 0) == 15; //diag1
  a.sum() with ((item.index(1) + item.index(2) == 2) ? item : 0) == 15; //diag2
In reply to sam33rs:
I see syntax errors with this code.
Is it working for you?
Error - This type is illegal in this context [SystemVerilog].
Regards,
Naveen
In reply to naveensv:
Works for me.
constraint c {
You can further simplify with a loop:
class magicsquare;
  int i,j,k;
  constraint c1 {
        foreach(a[i,j]) {
            a.sum with (item.index(1) == i ? int'(item): 0) == 15; // rows
            a.sum with (item.index(2) == j ? int'(item): 0) == 15; // cols
        a.sum with (item.index(1) == item.index(2) ? int'(item) : 0) ==15; // diag1
        a.sum with ( (item.index(1) + item.index(2)==2) ? int'(item) : 0) ==15; // diag2
I tried a different approach that involves matrix transpose. Its definitely much lengthier than the solutions described here, but this solution might scale better than the solution described above.
class magic_square#(int grid_size=4);
  rand bit[4:0] rand_array[grid_size][grid_size];
  rand bit[4:0] rand_array_transpose[grid_size][grid_size];
  rand bit[4:0] diagonal_0[grid_size];
  rand bit[4:0] diagonal_1[grid_size];
  rand int unsigned rand_sum;
  constraint magic_square_cnstr {
    rand_sum >= 0;
    rand_sum <= 8'hFF;
    foreach(rand_array[i]) {
      unique{rand_array[i]};
      rand_array[i].sum() with (int'(item)) == rand_sum;
    foreach(rand_array[i,j]) {
      rand_array_transpose[j][i] == rand_array[i][j];
      if (i==j) {
        diagonal_0[i] == rand_array[i][j];
      if ((i+j) == grid_size-1) {
        diagonal_1[i] == rand_array[i][j];
    foreach(rand_array_transpose[i]) {
      unique{rand_array_transpose[i]};
      rand_array_transpose[i].sum() with (int'(item)) == rand_sum;
      foreach(rand_array[i1,j1]) {
        if ((i!=i1) && (j!=j1)) {
          rand_array[i][j] != rand_array[i1][j1];
    diagonal_0.sum() with (int'(item)) == rand_sum;
    diagonal_1.sum() with (int'(item)) == rand_sum;
  function post_randomize();
    string row_print;
    $display("Solving for grid_size:0x%0x sum:0x%0x", grid_size, rand_sum);
    foreach (rand_array[row]) begin
      row_print = {row_print,$sformatf("%p \n", rand_array[row])};
    $display ("%s", row_print);
  endfunction // post_randomize
  endclass // magic_square
module magic_square();
  magic_square #(4) ms = new();
  assert(ms.randomize());
endmodule // magic_square
class matrixsum;
int i,j,k;
constraint c1 {
foreach(a[i,j]) {
a.sum with (item.index(1) == i ? int’(item): 0) == 15; // rows
a.sum with (item.index(2) == j ? int’(item): 0) == 15; // cols
a.sum with (item.index(1) == item.index(2) ? int’(item) : 0) ==15; // diag1
a.sum with ((item.index(1) + item.index(2)==2) ? int’(item) : 0) ==15; // diag2
$display (“The value of array is %p” , a);
module test;
matrixsum m1;
repeat(3) begin
m1=new();
m1.randomize();
m1.display();
Here in bold syntax. what’s the requirement? and how it will work? I want to know the logic behind that 4 syntaxes. but why another value other than 12 and 15 is not applicable to get the sum as that replaced value of 15 in this code.
here, whats use of item.index(1) == item.index(2) and (item.index(1) + item.index(2)==2 and
    a.sum with (***item.index(1) == i ? int'(item): 0***) == 15; // rows
    a.sum with (***item.index(2) == j ? int'(item): 0***) == 15; // cols
 a.sum with ( ***item.index(1) == item.index(2) ? int'(item) : 0***) ==15; // diag1
 a.sum with ( ***(item.index(1) + item.index(2)==2) ? int'(item) : 0***) ==15; // diag2
here, why only index(1) & index(2) is taken why not others else ? give me satisfactory answers of my questions.
In reply to Bansari Patel:
Because the matric is 2 dimensional. Here index(1) refers to row and index(2) refers to column
Hi prasadaddagarla,
When I extended for 4x4 matrix all satisfies except diag1
{'{'h5, 'h3, 'h3, 'h4}, '{'h0, 'h7, 'h5, 'h3}, '{'h5, 'h3, 'h1, 'h6}, '{'h5, 'h2, 'h6, 'h2}}
How can we generalise this for nxn matrix?
Thanks !!!
In reply to UVM_geek:
The previous solutions are wrong. See 2D array constraint randomization | Verification Academy
The correct solution is
class magicsquare;
  parameter int N = 4;
  rand bit [7:0] a [N][N];
  constraint c1 {
    foreach(a[i,j]) {
      a[i].sum(row) with (int'(row)) == 15; // rows
      a.sum(row) with (row.sum(col) with (col.index == j  ? int'(col) : 0))== 15; // cols
      a.sum(row) with (row.sum(col) with (row.index==col.index ? int'(col) : 0 )) == 15; // diag1
    a.sum(row) with (row.sum(col) with (($size(a)-row.index-1)==col.index ? int'(col) : 0)) == 15; // diag2
    $display ("The value of array is");
    foreach(a[i]) $display("%p = ",a[i], a[i].sum(row) with (int'(row)));
    foreach(a[,j]) $write("%3d ",a.sum(row) with (row.sum(col) with (col.index == j  ? int'(col) : 0)));
    $display("\ndiag1 = ", a.sum(row) with (row.sum(col) with (row.index==col.index ? int'(col) : 0)));
    $display("diag2 = ",  a.sum(row) with (row.sum(col) with (($size(a)-row.index-1)==col.index ? int'(col) : 0)));
module test;
  magicsquare m1;
    m1=new();
    assert (m1.randomize());
    m1.display();
Thank you so much DAVE !!!
I tried your solution in simulator to understand: a.sum(row) with (row.sum(col)
and it give error saying col not defined.
Error-[IND] Identifier not declared
testbench.sv, 10
Identifier ‘col’ has not been declared yet. If this error is not expected,
please check if you have set `default_nettype to none.
Instance stack trace:
$unit /apps/vcsmx/vcs/S-2021.09//etc/uvm-1.2/src/uvm.sv, 1
testbench.sv, 10
In reply to curious_verifier:
Please see 2D array constraint randomization | Verification Academy
the above link is not working : " Oops! That page doesn’t exist or is private."
There was a bug in the forum software we are using that has been addressed. Please refresh this page before clicking on the link
