As the local variable is initialized on each attempt , if I were to re-write the sequence as ::
sequence dataCheck_2;
int local_data = rData ; // Initialization is now done during declaration itself
##5 rdc ##0 ( wData == local_data + 'hFF );
endsequence
Are there any subtle difference(s) between the two sequences ? In both cases won’t the local variable ‘local_data’ be assigned in Observed region the value of rData sampled in pre-poned region ?
This is no different from any other variable initialization used in procedural code. You can choose to make a declaration initialization or treat its first assignment as an initialization. The declaration initialization occurs earliest.
