Is task or automatic task synthesizable using verilog (not System Verilog)?
In reply to Ayesha1:
It should be as long as all the statements inside the task (its body) are synthesizable as well. Understand that the body of code gets expanded into the always block that calls the task.
Thank you Dave!
I am using verilog, not SystemVerilog. This is my code. I am getting error. Do you see any issue here?
module Task (
input [7:0] a,
input [7:0] b,
output reg [7:0] c,
output reg [7:0] d
task automatic reverse_bits_task;
input [7:0] in;
output [7:0] out;
integer index;
for (index=0; index<8; index=index+1) begin
out[7-index] = in[index];
always @(a,b) begin
reverse_bits_task(.in(a),.out(c));
reverse_bits_task(.in(b),.out(d));
