I have a conceptual question about the way System Verilog works. To make this easy to explain, say that I have code which looks like this:
interface my_interface();
logic y;
always @(y) begin
$display("Activated!");
task set_y_zero();
y = 0;
task set_y_one();
y = 1;
endinterface
module test();
my_interface int();
int.set_y_zero();
#10
int.set_y_zero(); // Location A
#10
int.set_y_one(); // Location B
I know from experiments that “Activated!” will be printed when test reaches location B but not location A. However, I would like some way to detect when the task set_y_zero, i.e. “y is written to 0” is called a second time at location A. Unfortunately, all my research seems to indicate that this is impossible; System Verilog events seem to only be scheduled when there is a change. But I would like to confirm:
Is there any way to detect when a variable (logic in this example, but it can be anything) is ‘re-written’ to the same value?
If the variable is clocked, you can use the action block or statement to take an action. However, this are restrictions. Also, a reassignment is not necessarily detected. You can tune the assertion or the cover to what you need. For example:
cover property(property_spec) statement_or_null
cp: cover property( @(posedge clk) $rose(v) |=> v[->1]) $display("whatever");
// If new "v", then another "v" will happen
cp_next1: cover property( @(posedge clk) $rose(v) |=> v) $display("whatever");
cp_next0: cover property( @(posedge clk) $fell(v) |=> !v) $display("whatever");
The requirements were for the general case;the above solution requires the application of an event after every set of assignments. It won’t work for variables of type wire.
But it has value.
Ben Ben@systemverilog.us
