**I am trying to achieve the following :
int n = $urandom_range(1,20);
paramter int N = n;
Is there a way to do it?**
paramter int N = n;
In reply to assert_yourself:
parameter are meant to be constant.
To achieve overriding instantiate the module with different parameter value.
static variables initializations happen at time 0 at the start of simulation execution. Parameter assignments happen during compilation/elaboration before simulation starts. Parameters can be used to make assignments to other parameters or variables, but you cannot make an assignment from a variable to a parameter.
