I am Tarun.I have a doubt in writing constraint. In a part of my code I have given a constraint in packet(class) definition,
as follows
class packet ;
rand real m1[0:size-1]; // size is a parameter which can be configured
constraint c1{ m1 == '{default: 4.4};}
endcalss //packet
When i am simulating it in vcs it is giving an Error like this “The expression ‘default:0’ is not yet supported in constraints in this context.”
I am confused that whether this kind of decalration is valid or not? Some simulators are passing it but some of them are not passing it. What is the problem in it?
Please help me.
The example you provided is invalid SystemVerilog code and will never work. You are trying to use the reserved keyword ‘input’ as an identifier, which is a LRM violation. Also, you cannot randomize a real variable.
You should post the exact code you are having issues with along with the exact error messages.
Hi jagan I did not know whether it is possible or not but the following code is working well,there are no errors.
class rand_real_freq;
rand real a;
constraint c1 {soft a == 0.4441;}
program p;
rand_real_freq rr;
rr=new();
repeat (10) begin
assert(rr.randomize() with { a inside {[0:0.100]};});
$display(“a=%0f \n”,rr.a);
endprogram
Non-integer datatypes are allowing in this case.
Please corrcet me if i am wrong.
VCS, Questasim and NCsim are mostly LRM Compliant and doesnt allow rand real. Iam not sure of iRun. They might have allowed real numbers to get randomized. If you really want to randomize real numbers, then check this links
Random ‘real’ number can be selected by randomizing non-integral variable and passing it to built-in SV 1800-1200 Mathematics Function which gives real number. Input to built-in math function should be controlled as per desired result.
E.g.
// Purpose: Randomize non-integer(real, shortreal, realtime) values
class non_integer;
rand int in;
real in1;
constraint c_in {in > 1;}
in1 = $ln(in);
endfunction // post_randomize
endclass // non_integer
initial
non_integer ni;
ni = new();
if(!ni.randomize())
$display("Randomize failed");
$display("Non Real Number: in = %d", ni.in);
$display("Real Number: in1 = %f", ni.in1);
endmodule // top
Randomization of a real variable is not supported in SV 1800-1200. And still there is a requirement to get random real number, so it can be achieved with alternate/work-around only.
Sometime results are more important than the way chosen to do it.
Randomization of real numbers is not legal in the current standard, but is being considered as a future enhancement. Most vendors have already implemented some parts of it, and you will have to check with them as to what options may be needed.
In any case, there a number of general problems with real number math in computer science that you should be aware of. One of them is using equality operators with real numbers. Due to various rounding errors, you should be comparing numbers numbers using a tolerance instead of using equality.
(real_variable - real_constant) < real_tolerance
Another problem with your constraint is you need to use a foreach when applying a constraint to each element of an array.
