I am stuck at one point which is as below.
I am having 2 different agents for single environment 1 is active and 1 is passive now I want to use interface of active agent into monitor of passive agent so how can it be done. Interface of passive agent is being used in monitor already.
Can anyone guide me the way to do it.
Thank You in Advance
In reply to om30:
I believe you have to re-work your architecture. Or can you explain why you need 2 monitors for the same interface?
I am having 2 interfaces that’s why I have 2 agents so 1 is active and other passive now my protocol is such that monitor of passive agent needs 1 signal from interface of active agent then it uses its own interface for other signals
In reply to om30:
You could have this signal in both interfaces. There is no restriction.
