Inserting Wishbone Driver for Verification
Hello Everyone,
I have a Wishbone Compliant IP Master I2C Core and I have its TB as well for inserting the values in its registers in order to activate the core. e.g to send a Start condition, to transmit address, etc. Now i am making a slave driver to verify the core but unfortunately i have found out that firstly I have to initiate the core by setting register values of core. Now, I am really confused that where should I put that TB in my Verification environment. Of course, I cannot put it this TB in my verification component. Should I instantiate my TB in my TOP module? OR should I write my whole TB in TOP Module. Of course I will have to Instantiate the DUT as well in TOP Module.
Any Ideas, Any Suggestions? What do u recommend? Has anyone faced this situation already?
In reply to khnabeel:
You need to create wishbone master environment first.I created a separate class for tests in a task inside that class.This task sends the transactions to driver.Using this class instance,I ran that test task in generator class.
In reply to rajan passionate:
What do u mean? I didn’t completely understood this thing. I don’t want to write Wishbone Interface. I am trying to to use the TB that sets register values in my TOP module. Can you please elaborate more? I will be thankful to you. Do u have any example with you? may b in a block diagram? or somehow?
What I understood is that you made a separate class in test. Now this class sends Seq_items to sequencer? And this sequencer sends those transactions to driver?
In that separate class have u instantiated TB? or u had written wishbone interface? I am really confused.
Actually I did in SV only not in UVM.I wrote TB using wishbone interface signals.Can you please elaborate more about your TB?Was it a verilog TB?If not what are the components in your TB ENV?Then I can help you.
Yes, This TB is written in Verilog where we are using WBC signals to set the registers inside IP core. Actually I have to use this TB inside UVM environment. But I am not getting an idea that how can I use that TB inside UVM environment. This TB is driver for that core and only this TB can initiate the core.
Until and unless you convert that TB into SV compatible one,it’s difficult to proceed further.
And after converting… What should I do? I mean what will be the further steps? How should I proceed? I am confused that if I have this TB. How can I use this inside UVM environment?
First you convert in into task based SV TB and then you will only understand how to do it.If any difficulty, I am there to help.
