Input needed: Assertion module initiated from UVM's Top module
Hi All,
I have instantiated another module (slave_con_assert) in UVM’s top module for Concurrent assertions (Since we cannot use inside any class)
I’m passing DUT-Interface, global CLK and RESET signal to the assertion module.
My query is
  1. Will the ASSERTION-module be updated according to the DUT-interface ??
  2. Can i continue by adding other check points in Concurrent-assertions ??
  3. Is there any other better way to serve my purpose ??
    Kindly help me out !!
    Thank you!!
For reference I’m attaching my code (not tested) here:
module top();
	bit clk;
	logic reset=1'b1;
	//AHB Bus and Slave Instantiation
	ahb_if ahb_top_i(clk, reset); 		// Interface
	ahb_slave2 slave2(ahb_top_i); 		// DUT
	concurrent_assertion slave_con_assert(ahb_top_i, clk, reset); // For the sake of Concurrent Assertions
	initial
			//Reset condition
			#1 reset=0;
			ahb_top_i.HTRANS='d0;
			ahb_top_i.HADDR=32'b0;
			ahb_top_i.HWRITE='b0;
			ahb_top_i.HBURST='d0;
			ahb_top_i.HSIZE='d0;
			ahb_top_i.HWDATA=32'bz;
			#10 reset=1;
	always
		#5 clk = ~clk;
	initial
			uvm_config_db#(virtual interface ahb_if)::set(null,"*","ahb_if",ahb_top_i);
			`uvm_info( get_name() ,"start test",UVM_NONE);
			run_test("ahb_test");
		$dumpvars();
		$dumpfile("ahb.vpd");
endmodule:top
interface ahb_if(input clk, input reset);
	logic[31:0]		HADDR;
	logic			HWRITE;
	logic [2:0] 	HSIZE;
	logic [2:0] 	HBURST;
	logic [1:0] 	HTRANS;
	logic [31:0] 	HWDATA;
	logic			HREADY;
	logic			HRESP;
	logic[31:0]		HRDATA;
endinterface
module concurrent_assertion (ahb_if ahb_top_i, input clk, input reset);
	int basic_burst_write_check_Pass,basic_burst_write_check_Fail;
	property basic_burst_write;
	@(posedge clk)
	disable iff (ahb_top_i.HTRANS == BUSY)
		((ahb_top_i.HWRITE==1)&&(ahb_top_i.HTRANS == NON_SEQ) )|=>(ahb_top_i.HREADY=='1) ;
	assert property(basic_burst_write)
		basic_burst_write_check_Pass++;
		basic_burst_write_check_Fail++;
	final
		$display( " basic_burst_write_check\t\t%d\t\t%d\t\t%d      ", (basic_burst_write_check_Pass+basic_burst_write_check_Fail),basic_burst_write_check_Pass,basic_burst_write_check_Fail);
In reply to vvv:
My query is
[Ben] Absolutely YES.
  1. Can i continue by adding other check points in Concurrent-assertions ??
  1. Is there any other better way to serve my purpose ??
[Ben]
  1. I recommend that you read my paper entitled SVA in a UVM Class-based Environment
    located in
  2. You can put assertions inside interfaces. You can also copy from UVM needed variables declared in the classes into interface variables, and use those interface variables in your assertions.
  3. You can also write assertions inside checkers and bind the checkers to interfaces and modules. I also explain the use of checkers in my SVA book.
  4. You can use default clockings and defaults resets instead of declaring the clocking event and disables in your assertions. For example:
default clocking cb_clk @ (posedge clk); endclocking
default disable iff (rst);
  1. Use the UVM severity levels instead of $displays in you action blocks. For example:
ap_LOW: assert property(a) else
`uvm_info(tID,$sformatf("%m : error in a %b", a), UVM_LOW); // Line 9
ap_MEDIUM: assert property(a) else
`uvm_info(tID,$sformatf("%m : error in a %b", a), UVM_MEDIUM); // Line 11
ap_HIGH: assert property(a) else
`uvm_info(tID,$sformatf("%m : error in a %b", a), UVM_HIGH); // Line 13
ap_FULL: assert property(a) else
`uvm_info(tID,$sformatf("%m : error in a %b", a), UVM_FULL); // Line 15
ap_test2: assert property(a) else
`uvm_error(tID,$sformatf("%m : error in a %b", a)); // Line 17
Other papers that might be of interest to you of interest to you.
See my White paper: “Using SVA for scoreboarding and TB designs”
http://SystemVerilog.us/papers/sva4scoreboarding.pdf
and a related issue at the Verification Academy the following paper
“Assertions Instead of FSMs/logic for Scoreboarding and Verification”
available in the verification-horizons October-2013-volume-9-issue-3
Browse all content in Verification Academy: Articles, Cookbooks, Resources, Sessions, and Tracks
and “SVA in a UVM Class-based Environment”
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
Thank you Ben, Info/Materials which you provided are really helpful!!
I will according modify my code and practice the same.
