Inheritance of clock for sequence used as event control
Hi All,
Consider the following code ::
 default clocking cb @(posedge clk); endclocking
  sequence  sr1;
     req ##2 gnt ;  // No explicit clocking event
  endsequence
  always @( sr1 )
    $display(" TIME : %3t  Sequence  sr1  completes " , $time)
On trying this on 2023 version of licensed tools I observe ::
2 tools treat the code legal i.e sr1 inherits the clock from default clocking block whereas
1 tools throws a compilation error : “Use of a method on an unclocked sequence is illegal.”
[Q] Does the LRM say that the default clock will be inherited by the sequence sr1 ?
If yes,could you please point to the respective LRM section ?
14.12 Default clocking
One clocking block can be specified as the default for all cycle delay operations within a given module,
interface, program, or checker.
So I would argue that the compile error needs a fix in the tool.
Thanks Srini.
I am looking at LRM 16.16 Clock resolution ::
In a module, interface, program, or checker with a default clocking event, a concurrent assertion
statement that has no otherwise specified leading clocking event is treated as though the default
clocking event had been written explicitly as the leading clocking event.
I believe the above quote is applicable as well.
Yes, for any concurrent SVA in that module. In your test code, you didn’t show one though.
My apologies Srini. I was testing the code within a module.
