Importing a macro in a class
I am trying to import a macro in a class
The package code
package pkg;
`define CLOCK_WIDTH 20
endpackage
Driver code
task drive();
vif.reset = 1;
#(pkg::`CLOCK_WIDTH/2);
vif.reset = 0;
endtask :drive
But I am facing this error message
**Error-[UC] Unexpected character
The character ‘2’ is illegal in the context.
“driver.sv”, 73 (expanding macro)
Source info: #(pkg::`CLOCK_WIDTH/2);
How to resolve this one
NB: Package pkg is imported in top.sv before the compilation of driver.sv
In reply to bachan21:
A `define is a compile time directive and can’t be imported from a package.
Use a parameter instead.
In reply to cgales:
Sure cgales.
Thanks for the help
In reply to cgales:
but below code works fine
package my_pkg;
  `define CLOCK_PERIOD 10
endpackage
module main;
   import my_pkg::*;
       $display("clock peripod = %0d",`CLOCK_PERIOD/2);
In reply to Desam:
That’s because the `define is being processed in the same file that it is being used in, so it is valid in this scope.
If you create two separate files and compile them separately, you will see a failure.
In reply to cgales:
sure…Thanks for clarification
In reply to Desam:
Note that if you had written
package my_pkg;
endpackage
module main;
It still would have worked without the import. This is because macros get pre-processed and expanded before without any regard to SystemVerilog syntax.
