Implementing Outstanding AXI transactions using RAL
Hi All,
I am using AXI4 adapter to write/read registers using UVM RAL.
I notice that the write / read RAL API tasks don’t unblock till a respective RRESP/BRESP is received.
( our adapter flags an uvm_error incase RRESP/BRESP is Not OK )
Although AXI4 protocol supports pipelined / outstanding transactions,
user can’t initiate multiple write / read transactions due to following code in UVM library ::
  // Within class uvm_reg_map::do_bus_write / uvm_reg_map::do_bus_read
   if (adapter.provides_responses) begin  // True since driver sends Response
      uvm_sequence_item  bus_rsp;
      rw.parent.get_base_response(bus_rsp);  // write/read task blocks here
      adapter.bus2reg(bus_rsp,rw_access);
   else begin
      adapter.bus2reg(bus_req,rw_access);
I wanted to know whether one can achieve outstanding transactions via UVM RAL ?
Reference to any papers / docs / edacode that we could use as guidance would be extremely helpful
Arshi
The RAL is implemented to treat register accesses as atomic operations. This ensures that there is no potential for register mis-matches if multiple reads/writes were to happen to the same register at the same time.
The use of atomic transactions for register reads/writes is also typically used in real software for the same reason.
