Implementing Hardware Model, which language is preferred? SystemC or System Verilog(UVM)?
If System Verilog, what are advantages to SystemC or vice-versa
In reply to hrishikeshadn:
There is no rule. The question is “What is available?” or “what is a useful language” to implement a reference model. Mostly it depends on the application you have.
The answer to your question is highly opinionated. It may come down to where you have experience or resources available to help you through the process.
In general, certain kinds of applications will favor certain languages (and remember SystemC is not a language; it is a library on top of the C++ language). It might be easier to express the description of an application in one language as well as getting better performance.
SystemC is certainly favorable for large data-centric, algorithmic, and untimed models; whereas SystemVerilog is better suited for bit-level, event-driven, multiple clock or asynchronous models.
Reference models is really a very broad story. Even unusual approaches are possible, as holding a reference model in Matlab and connecting this directly to an UVM environment.
