IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, November 8th at 3:00 AM US/Pacific.
Error-[SV-SNCIM] Super new call is missing 5soln.sv, 13 $unit Base class constructor specification is missing in derived class ‘sub_class’. Please add ::new arguments to ‘extends’ specification or add call to ‘super.new’
class base_class;
bit[15:0] data;
function new(bit[15:0] data/=6/);
this.data=data;
function display ();
$display (“[Base] data=%0h”, data);
class sub_class extends base_class;
bit[3:0] id;
bit[2:0] mode;
function new2(bit [3:0] id, bit[2:0] mode=2);
super.new(6);
this.id=id;
this.mode=mode;
function display();
super.display();
$display (“[Child] id=%h,mode=%h”,id,mode);
module tb;
initial
sub_class sc1=new();
sc1.new2(22,3);
sc1.display();
Hi Sir,
In the code if the base class is declared with the value 6 there is no error,but when I try to assign value using super.new(6) then the error is seen.
Is it because of the base’s new is always called, but the “data” argument is NOT provided for the IMPLICIT call to new in base_class.
Even then 1)Add default argument in constructor of base class.
—function new(bit[15:0] data=6)—
2)Explicitly call super.new with required arguments.
------super.new(6);-----
Both should have worked but I see only first option is working for the above code.So should I follow only first option??
It’s difficult to make-out anything from data you shared. can you show the full code ?
Example code:
class C;
int c3;
function new(int a = 5);
c3 = a;
class D extends C;
int d1;
function new;
super.new(10);
d1 =4;
module my_module;
D d;
d = new();
If you want to create an explicit user-defined new method (even in extended class), you must use the “function new()” not “function new2()”
As you have a custom user defined new method() in base class, you must declare the explicit user-defined new method in extended class. (Just change the new2() to new(), it should work)
Every class have new constructor function. If a class does not provide an explicit user-defined new method, an implicit new method shall be provided automatically. The new method of a derived class shall first call its base class constructor super.new().
Let take your sub_class example.
bit[3:0] id;
bit[2:0] mode;
super.new(6);
this.id=id;
this.mode=mode;
function display();
super.display();
$display ("[Child] id=%h,mode=%h",id,mode);
It doesn’t have explicit user-defined new class constructor method. new2 method define by you isn’t constructor. so here implicit new method shall be provided automatically which have code something like this.
function new();
super.new();
But your base class need super.new(6) instead of super.new() if you don’t have default value to argument data in base new method. so it was giving error when you didn’t define default value.
function new(bit[15:0] data/*=6*/);
this.data=data;
so if you don’t define default value to argument in base new method and don’t have explicit call to super.new with argument value then you will get error.
Let fix your example:
class base_class;
bit[15:0] data;
this.data=data;
$display ("[Base] data=%0h", data);
bit[3:0] id;
bit[2:0] mode;
//changed new2 to new, Now class have explicit new method
function new(bit [3:0] id, bit[2:0] mode=2);
super.new(6);
this.id=id;
this.mode=mode;
function display();
super.display();
module tb;
initial
sub_class sc1=new(22,3);
//sc1.new2(22,3);
sc1.display();
