//this block of code had a map name map now i want to link maps of both eth_reg_block and i2c_reg_block to a single map map
class mcs_try_reg_block extends uvm_reg_block;
uvm_object_utils(mcs_try_reg_block) mcs_eth_reg_block h_eth_reg_block; mcs_i2c_reg_block h_i2c_reg_block; uvm_reg_map map; virtual function void build(); h_eth_reg_block = mcs_eth_reg_block::type_id::create("eth_blk"); h_eth_reg_block.build; h_i2c_reg_block = mcs_i2c_reg_block::type_id::create("i2c_blk"); h_i2c_reg_block.build; endfunction endclass //this is block code for mcs_eth_reg_block class mcs_eth_reg_block extends uvm_reg_block; uvm_object_utils(mcs_eth_reg_block)
mcs_eth_IRQSTAT irqstat ;
mcs_eth_ISRSTAT_1_REG isrstat_1_reg ;
uvm_reg_map map;
function new(string name="mcs_eth_reg_block");
super.new(name,UVM_NO_COVERAGE);
irqstat = mcs_eth_IRQSTAT ::type_id::create("irqstat ");
irqstat .build();
irqstat .configure(this,null,"");
isrstat_1_reg = mcs_eth_ISRSTAT_1_REG ::type_id::create("isrstat_1_reg");
isrstat_1_reg.build();
isrstat_1_reg.configure(this,null,"");
irqstat .add_hdl_path_slice("TBD",0,16);
isrstat_1_reg.add_hdl_path_slice("TBD",0,16);
map=create_map("map",'h00,4,UVM_LITTLE_ENDIAN);
map.add_reg(irqstat , 16'h00, "RO");
map.add_reg(isrstat_1_reg, 16'h01, "RO");
add_hdl_path("","RTL");
lock_model();
similarky for i2c_reg_block
