How to write UVM driver and sequence item for a vending machine design (interview question)?
I was asked this question in a DV interview and I am curious to know what I missed or what can be a better way to do it . Please lend your suggestions.
Question:
I need to write pseudocode for seq item, driver and tell scenarios which I will check for verifying the following design:
A vending machine which has following :
  • inputs → amount, valid, done
  • outputs → soda_out, change
A soda costs $60. Amount can be 1, 2, 5 or 10 in dollars. Every time a currency is inserted, valid is high for the next cycle and once all currencies for the are inserted, done goes high for one cycle and soda_out output goes 1 if total is $60 and change comes out if its more that $60.
Here is what I wrote:
   class vending_pkt extends uvm_sequence_item;
     typedef enum {1,2,3,10} currency ;
     rand currency amount[];
     randc currency value;
     int change;
     bit soda_out;
     constraint c1 {amount.sum() >=60 ;}
    // to check if all all currencies inserted are same, i will turn this constraint on only for one seq
     constraint c2 { foreach(amount[i])
      amount[i]==value;
     //to check if all type currencies are inserted,  will turn this constraint on only for one seq
     constraint c3 {
                  amount.sum() with (int'(item == 1))>0;
                  amount.sum() with (int'(item == 2))>0;
                  amount.sum() with (int'(item == 5))>0;
                  amount.sum() with (int'(item == 10))>0;
**DRIVER RUN_PHASE :
virtual task run_phase(uvm_phase phase)
    drive(req);
    seq_item_port.item_done()
    virtual task drive(vending_pkt req)
    int i=0;
    repeat(req.amount.size())
     vif.cb.amount<=req.amount[i]
     @(posedge vif.cb)
     vif.cb.valid<=1'b1;
     @(posedge clk)
    i++;
   vif.cb.done<=1'b1;
For the scenarios, I thought of checking if same kind of currencies are inserted, all different currencies are inserted or random, if sum is exact $60, if sum is $59, sum is $61.Please let me know your thoughts or test scenarios you can think of as DV person.
I think since the amount ‘can’ be 1,2,5,or 10 dollars, this particaluar testcase always sums up the amount to 16 dollars every 4 cycles except the 4th time of 4 cycles because the value has been declared as randc, however it can be made more robust by replacing it with rand, which is to say even without one of the denomination amounts you can verify the design.
