I have been working on a verification model of an american car tail light controller RTL. UVM structure has all the necessary VC’s including scoreboard. I need to discuss, what should be the predictor function in this case to check the integrity of scoreboard and compare with the actual data of DUT with the expected data?
module carlights(
// Input
clk,
rst,
br,
lf,
rt,
haz,
// Outputs
lights
// Input Declaration
input clk;
input rst;
input br;
input lf;
input rt;
input haz;
// Output Declaration
output [5:0] lights;
// Internal Registers Declaration
reg Break ;
reg Left ;
reg Right ;
reg Hazard;
reg [5:0]left_out; //Lights flags on indicators
reg [5:0]right_out;
reg [5:0]haz_out;
reg [3:0] left_state;
reg [5:0]lights;
// Internal Wires Declaration
wire f_break,f_left, f_right, f_haz, f_break_rt, f_break_left;
wire Flash_pattern ;
wire all_off ;
wire ff_haz;
/*++++++++++++++++++++++++++++++++++++++++++++++ MULTIPLEXER I/O +++++++++++++++++++++++++++++++++++++++++++++++++*/
//--------- Break << Left << Right << Hazard ----------//
assign f_break = (br)&(~lf)&(~rt)&(~haz);
assign f_left = (~br)&(lf)&(~rt)&(~haz);
assign f_right = (~br)&(~lf)&(rt)&(~haz);
assign f_haz = (~br)&(~lf)&(~rt)&(haz);
assign f_break_rt = (br)&(~lf)&(rt)&(~haz);
assign f_break_left = (br)&(lf)&(~rt)&(~haz);
assign all_off = (~br)&(~lf)&(~rt)&(~haz);
assign ff_haz = ((~f_break)&(~f_left)&(~f_right)&(~f_break_rt)&(~f_break_left)&(~all_off))|(f_haz); //consistant hazard flashing-none other signal
always@(*)
case ({f_break,f_left,f_right,ff_haz,f_break_rt,f_break_left})
//6'b000000: lights <=6'b000000; //this might be a problem
6'b100000: lights <=6'b111111;
6'b010000: lights <=left_out;
6'b001000: lights <={3'b000,left_out[3],left_out[4],left_out[5]} ; //right_out
6'b000100: lights <=haz_out;
6'b000010: lights <={3'b111,left_out[3],left_out[4],left_out[5]} ;//break_right_out;
6'b000001: lights <={left_out[5:3],3'b111}; //break_left_out;
endcase
assign Flash_pattern =(f_left|f_right|f_break_rt|f_break_left);
//FSM
// left_out block
always@(posedge clk or rst)
if(rst)
left_state <=4'b0000;
left_out <=6'b000000;
else //if(f_left|f_right|f_break_rt|f_break_left)
//"left_state" is basically counter type thing (just bit 1 shifting) just adding at every iteration
//Flashing pattern is defined here
case (left_state)
4'b0000: begin
left_out<=6'b000000;
if(Flash_pattern)
left_state <=4'b0001;
4'b0001: begin
left_out<=6'b001000;
left_state <=4'b0010;
4'b0010: begin
left_out<=6'b011000;
left_state <=4'b0100;
4'b0100: begin
left_out<=6'b111000;
left_state <=4'b1000;
4'b1000: begin
default: begin
endcase
// haz block
always@(posedge clk or posedge rst)
if(rst)
haz_out <=6'b000000;
else begin
haz_out <= 6'b111111;
if(ff_haz)
haz_out <=~ haz_out;
