In practice, what is the common way to check functionality of a clock divider(e.g. freq: clk_o=1/2 or 1/4 clk_i) using SVA. given clk_i, clk_o and ratio, could anybody provide an example?
Thanks in advance.
In reply to philerpeng:
You need to start with the requirements. Thus, for a 1/2 clock, you could first write something like: chall toggle
- Given a system master clock “clk”, there shall be a half clock “clk2” and a quarter clock “clk4”, all of which are generated from the master clock.
- “clk2” clock shall toggle at each posedge of the master clock “clk”, and its output shall have a maximum hold time of Xns.
- “Clk4” shall toggle when “clk2==0” at the posedge of the master clock “clk”. “clk4” output shall have a maximum hold time of Xns.
Once you have a spec, it becomes trivial to write assertions. Remember, the assertions are a reflection of the requirements.
ap_clk2: assert property(@(posedge clk) ##1 |-> clk2==!$past(clk2));
ap_clk4: assert property(@(posedge clk) #2 clk2==0 |->
clk4==!$past(clk4,2));
// The antecedent ##1 and ##2 are just used for initialization, since the clk2 and clk4 have not started.
// You need to look at the initial conditions.
// This code is not tested, but it looks ok to me. Needs testing anyway.
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
- SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy - SVA: Package for dynamic and range delays and repeats | Verification Academy
- SVA in a UVM Class-based Environment
Thanks ben, let me try it.
Hi Ben,
I just learn by other’s examples.
So for the first assertion, it will work but the question comes if the clk2 toggles before the next edge of clk1, the assertion will still pass.
How can one make sure the clk2 is actually 1/2 of clk1 but not an approx?
In reply to devil47:
You can write logic that measures the duration of the clocks
Edges and the relationships (delays) between clock edges of clocks.
They should be within acceptable limits.
See. checking clock period using system verilog assertion | Verification Academy
Ben systemverilog.us
