How to use Generate loop inside Interface to create clocking block
Hello ,
Can anyone have idea how we can use generate statement in interface file to create a clocking block ?
Currently trying with :
 interface abc_if #(int NO_Input=3);
  logic [NO_Input-1 :0 ] xyz_o;
  logic [NO_Input-1 :0 ] clk_i;
   genvar i;
   generate
   for(i=0;i<NO_Input;i++)begin
   clocking abc_cb @(posedge clk_i);
       output xyz_o;
   endclocking
   endgenerate
   endinterface
Regards,
Nidhi
In reply to nidhigandhi:
Did you mean to write:
   for(genvar i=0;i<NO_Input;i++)begin : block
      clocking abc_cb @(posedge clk_i[i]);
         output xyz_drive = xyz_o[i];
   endclocking
   end : block
// then you can drive
    block[0].abc_cb.xyz_drive <= '1; // drives xyz_o[0]
endinterface
Note that you will need to index block[n] where n is a literal constant or parameter.
anybody pls give me idea,
how to assign one interface definition with two same address[31:0] and address[7:0] signal declaration in systemverilog
endclocking
end : block
endinterface
This piece of code is not working for me.
I see error “Clocking blocks are not allowed in this type of design unit [SystemVerilog]”
Without for loop it is going good but I need clk_i[i]. What can be the issue ? Thanks !
In reply to Andee:
The issue is your simulator. Try a different one.
