In reply to Balu_15:
How did you resolve this issue.
I am also facing the same issue, not able to terminate the UVM Simulation.
Please help.
What kind of not stopping do you face? Please explain.
By the way to stop the simulation using UVM there is 1 meachanism. It is the objection mechanism. This is the default way to stop a simulation in the operational mode. And it has to be implemented. If there are no objections the simulation stucks at runtime 0.
If somethinh goes wrong in your simulation and the obejction mechanism does not work you have the option to set a timeout. This becomes active only in the error case.
Thank you for replying.
This issue is resolved, after adding below code to uvm test
task delay_to_end(uvm_phase phase); #1;
`uvm_info(get_name(),$sformatf(“Now to end %s…”,phase.get_name()),UVM_LOW)
phase.drop_objection(this);
function void phase_ready_to_end(uvm_phase phase);
if(phase.get_name == "main")begin
`uvm_info(get_name(),"Not yet to end...",UVM_LOW)
phase.raise_objection(this);
#1;
this.delay_to_end(phase);
join_none
You should only raise_objection() and drop_objection() in the run_phase() of your tests, using the phase itself (i.e. phase.raise_objection() and phase.drop_objection()).
Your test should look something like this:
task run_phase( uvm_phase phase);
phase.raise_objection( this );
test_seq.start( test_sequencer );
phase.drop_objection( this );
You should only raise/drop objections one time in the test.
