How to print hexadecimal numbers in upper case
In system verilog, when we use $display to print hex numbers, they are in lower case. For example, the following statement:
$display("var=%0h", var)
will get “var=af”.
How can I get “var=AF” with $display?
Hello!
Try one of these 2 methods (or both) and get back to me as I’ve done this on Python and not in SV.
  1. $display(“var = %0h{:H}”, var);
  2. $display(“var = %0H”, var);
Please inform if both are working or aren’t or if any one is working.
Hope it helps.
In reply to Aaron_Cui:
SystemVerilog has a toupper() string method.
   logic [15:0] val = 16'hcafe;
   string sval;
      sval.hextoa(val);
      $display("val= %s", sval.toupper());
In reply to Shashank Gurijala:
Hi Mr. Gurijala,
Thanks for your reply. Bad news that neither method works.
Hi Mr. Rich,
Thanks for your reply! Seems that this is the only way.
Sorry :(
Hi Dave!
Thanks for the solution. But is there a function to convert uppercase letters to lowercase?
See section 6.16 String data type in the IEEE 1800-2017 SystemVerilog LRM.
