Hi
I am trying to assert the same generic assertion for multiple registers
So I have io_conf1_reg, io_conf2_reg registers and for each of these registers -I want to assert the same assertion 2 times:
Assertion: AST_REG_WRITE_CHECK : assert property (REG_WRITE_CHECK_DUE_TO_TRIGGER(clk, register_disable_conditions , register_to_write , register_write_condition));
For the two registers -I want the following outcome:
AST_REG_WRITE_CHECK : assert property (REG_WRITE_CHECK_DUE_TO_TRIGGER(clk, register_disable_conditions , io_conf1_reg , register_write_condition));
AST_REG_WRITE_CHECK : assert property (REG_WRITE_CHECK_DUE_TO_TRIGGER(clk, register_disable_conditions , io_conf2_reg , register_write_condition));
Can someone recommend a way of doing this- note I have only two registers here-in reality I need to repeat this assertion about 30 times for 30 different registers
I have tried using define macro in a generate loop- however that does not use the actual generate loop value
