`define num =4
module enhance();
logic ssp , br ,clk , reset;
genvar i,j;
generate
begin:upstream
for(i=0;i<2*`num;i++)begin
ocp_level ocp(clk,reset); //interface
assign i.data = `wrapper.signal.val;
assign i.mdata= `wrapper.signal.read;
if(j<`num) begin
assign i.updata = `wrapper.signal.val;
assign i.upmdata= `wrapper.signal.read;
j=(i/2)+1; ----------------1.
endgenerate
Here I am using generate block .
case1. when both j and i is defined as genvar, than increment done in point 1 is not valid one, as we cannot update genvar inside the generate block.
or
case2 . if I take j as int than increment done in point 1 is valid but it throw error at if statement saying that it should elaboration time constant.
but cant even add initial begin becz I have interface in my code which I want it to work with generate loop.
So please suggest the way I can increment the if loop.
`num 3;
module abc
genvar j,var,i;
generate
begin: up
for(j=0;j<2*`num;j++) begin:inst
interface cond(clk,rst);
assign cond.cmd=value;
for(i=j;i<=j;i++)begin: block
if(i<`num)begin
assign cond.cmddd=value;
endgenerate
inteface xyz;
inital begin
for(int a=0;a<`num;a++)begin inst_val
up.inst[a].obj=new();
if(a<`num-`val)begin
up.inst[a].obj_ip=new();
over here at pt1 facing error [XMRE]cross module refernce resolution…how to solve this error.Tried to change the hierarchy of generate block but still facing the same issue.
num 3; module abc genvar j,var,i; generate begin: up for(j=0;j<2*num;j++) begin:inst
containet #(virtual interface) obj_ds;
if(i<`num)begin
containet #(virtual interface) obj_us;
endgenerate
inteface xyz;
inital begin
for(int a=0;a<num;a++)begin inst_val up.inst[a].obj_ds=new(); if(a<num-`val)begin
up.inst[a].obj_us=new();
To be more presice please see above code . Here i am facing cross modulation error
`define num 3
`define val 2
interface intf();
int a;
endinterface : intf
module abc();
class containet;
endclass : containet
genvar j,i;
generate
begin: up
containet obj_ds;
intf ivf();
if(i<`num) begin : block_if // Here give name to if block
intf ivf1();
containet obj_us;
endgenerate
genvar a;
generate
for(a=0;a<`num;a++)begin
up.inst[a].block[a].block_if.obj_us = new(); // Here , use proper hierarchical name.
endgenerate
Its illegal to use ‘int a’ variable for generate block array. You have to use generate block array inside generate block using genvar type.
