Fork join_none disable block is not working
always @(*)
begin //{
if (...)
  begin //{
         fork : LABELA
         join_none
  end //}
else if(....)
   begin //{
      disable LABELA;
    end //}
end//}
LABELA is not getting disabled. Please help
In reply to shamsheer:
And please see this article about posting better questions. The way your code is written, we have no way of knowing if
  • the fork ever got executed
  • the disable ever got executed
  • the fork finished before the disable
Hello Dave,
Thanks for adding code tags.
While fork (LABELA) is getting executed, disable LABELA statement was hit. But the fork (LABELA ) was not disabled.
You are still not showing enough code that might explain what might be going wrong. You might trydisable fork; instead.
module a();
  reg [3:0] i,j,k;
  always @(*)
    if(i == 1)
        fork : A
            #4;
            $display("%0t time A  is %0d",$time,i);
            #2;
            $display("%0t time B  is %0d",$time,i);
        join_none
    else if(j == 1)
      disable A;
      $display("%0t time D  is %0d",$time,k);
      $display("%0t time C ",$time);
  initial
      i = 0;
      j = 0;
      k = 0;
      #1;
      i = 1;
      #1;
      i = 0;
      #1;
      j = 1;
      #1;
Sorry dave. I could not share actual code. So, I created the above one.
Here is the output for the above one when I ran in eda playground
0 time C
2 time C
3 time D is 0
5 time A is 0
7 time B is 0
If disable A, would have worked . I should nt have seen time A and time B displays.
What you see is a Simulator Issue probably
2 out of 3 Simulators give an Output ( which is I believe is correct ) ::
0 time C
2 time C
3 time D is 0
After the following changes ::
always @(*)
    if(i == 1)
          begin:A // Naming after begin instead of fork !!
All 3 Simulators give Output ::
0 time C
2 time C
3 time D is 0
In reply to ABD_91:
The disabled fork construct gives the same result on all simulators on EDAplayground.
If this code was inside a class, the disable fork statement is preferred since it would be instance specific. Also putting a fork/join_none inside a always @* block is very dangerous because if you were to change multiple variables at the same time, there’s no guarantee if the block would fire once or multiple times for each change.
