Is there a way to flag an assertion that is still running at the end of the simulation as an error?
This is specifically for Questa, at least one other vendor has a switch for it.
Scott
Scott
In reply to snixon:
It depends on what you mean by “still running”. SystemVerilog assertions have strong properties like s_until that must be satisfied at some future clock cycle, otherwise it is considered a failure.
By still running I mean still active, i.e. it triggered the start but the implication was not met when the simulation ended.
In reply to snixon:
You can still code this strongly so that an assertion must pass during a simulation, otherwise it is a failure.
If you’re still looking for a magic switch, you 'll have to look at your tool’s User Manual for dealing with active assertions at the end of simulation.
Would prefer to code it, as some other assertions may still be running yet not represent failures.
Is the “until” properties the recommended way of coding it?
In reply to snixon:
That looked promising, but adding the “strong” keyword to my implication did not lead the the still running assertion being flagged at the end of the simulation?
In reply to snixon:
This was flagged as an assertion error after executing $finish:
bit clk,req,gnt;
property p;
@(posedge clk) req |-> strong(##[0:$] gnt);
assert property (p);
always #1 clk = ! clk;
@(negedge clk)
@(negedge clk) req = 1;
@(negedge clk) req = 0;
@(negedge clk) //gnt = 1;
@(negedge clk)
$finish;
Unfortunately not in my simulator version (Questa 10.6c_3).
No error, after $finish assertion is still shown as active.
Would have been a really elegant solution too…
In reply to snixon:
# // Questa Sim-64
# // Version 10.6c_3 linux_x86_64 Dec 21 2017
# // Copyright 1991-2017 Mentor Graphics Corporation
# // All Rights Reserved.
# // QuestaSim and its associated documentation contain trade
# // secrets and commercial or financial information that are the property of
# // Mentor Graphics Corporation and are privileged, confidential,
# // and exempt from disclosure under the Freedom of Information Act,
# // 5 U.S.C. Section 552. Furthermore, this information
# // is prohibited from disclosure under the Trade Secrets Act,
# // 18 U.S.C. Section 1905.
# Loading sv_std.std
# Loading work.top(fast)
# run -all
# ** Note: $finish : strong.sv(14)
# Time: 10 ns Iteration: 1 Instance: /top
# ** Error: Assertion error.
# Time: 10 ns Started: 5 ns Scope: top File: strong.sv Line: 6
# End time: 23:09:48 on Oct 23,2019, Elapsed time: 0:00:11
# Errors: 1, Warnings: 0
Same result in two other vendors’ simulator.
EDAPlayground
Doh, when you run with the “-onfinish stop” option enabled while doing interactive debug the simulation never actually ends hence no error message. Actually terminating the simulator leads to the expected error.
Thanks for your persistence, I will update my assertions to use the strong keyword!
Scott
