Factory over-ride mechanism for sequence
I have a base sequence in VIP. I need 2 BFMs of the same VIP. I also have to have 2 sequences which extend from the base sequence. I need to override the base sequence twice differently to produce these two sequences from the top. type_override by type produces only the latest over-ride request. Is there another way ? Kindly suggest.
Sree Krishna DS
you could use instance overriding with one of:
set_inst_override_by_type
set_inst_override_by_name Configures the factory to create an object of the override’s type whenever a request is made to create an object of the original type using a context that matches full_inst_path.
set_type_override_by_name Configures the factory to create an object of the override’s type whenever a request is made to create an object of the original type, provided no instance override applies.
See the UVM doc for more details.
In uvm-1.2/docs/html/index.html, Chapter “Factory”->“uvm_factory”
downloaded from UVM (Universal Verification Methodology)
Hope that was what you were looking for.
In reply to katce:
set_inst_override_by_type worked. Thanks katce.
In reply to SreeKrishnaDS:
You’re welcome!
