Enumarated data types
what is the meaning of enumarated data types and when to use it
In reply to Shivansh Bhardwaj:
See 1800’2017 6.19 Enumerations
The bottom line: It make the code mode readable. For example:
typedef enum {NOP, ADD, SUB, MULT, JMP, MOV, READ, WRITE, IDLE} instr_e;
typedef enum {FETCH, DECODE, EXECUTE}  mode_e;
typedef enum {PC, IR1, IR2, REGA, REGB, MAR, REG_FILE, STK} resource_e;
instr_e instr;
if(instr==READ) ...
// You can assign values to these elements
// The values can be cast to integer types and increment from an initial value of 0. This can be overridden.
enum {bronze=3, silver, gold} medal; // silver=4, gold=5
  3. Papers:
typedef enum{OKAY,BUSY,SPLIT,RETRY}resp_e
To indicate the different responses of protocols Ex:AHB
