Endless assertion, any other way to rewrite it?
I have an assertion in a bus arbiter, I want to check that the input request will be present at the output in less than 18 cycles.
I am using something like this, when there is a request, I store the request in a register. The assertion checks that before 18 cycles I will see an output request with the same address.
This assertion never pass or fail. I wanted to know if another style of coding this assertion could be better, so it could pass.
always_ff @(posedge clk)
if(reg_dr0.wr)
reg_dr0_reg <= reg_dr0;
req_dr0.wr & |(req_dr0.en) |-> ##[0:18] ram_req.wr & ram_req.addr == req_dr0_reg.addr
Regards
In reply to jcastillo:
The issue with your approach is that you are not necessarily capturing the value of reg_dr0 at the attempt phase as the if(reg_dr0.wr) may occur again at a later cycle. You really need to understand the concept of independent threads. This is how you fix this:
property p_req18;
    bit[31:0] v; //  assuming 32 bits
    (req_dr0.wr & |req_dr0.en, v=reg_dr0 )|->
        ##[0:18] ram_req.wr && ram_req.addr ==v;
ap_req18: assert property(@ (posedge clk) p_req18);
I strongly suggest that you carefully read my paper
Understanding the SVA Engine
Verification Horizons - July 2020 | Verification Academy
In it I used three different types of SVA properties are used to
emphasize different important concepts of SVA:
  1. Antecedent/consequent: This model demonstrates the concepts of spawned threads,
    leading clocking event, attempts.
  2. Range delays in the consequent: This model demonstrates the testing of each element of the
    range until success is reached and the lack of need to limit the ranges to a matched (i.e., valid) consequent.
  3. Range delays in the antecedent: This model demonstrates the testing of each element of the
    range and the need for a first_match operator or other technique to limit the ranges to a matched antecedent.
  3. Papers:
