Hello,
Is there any SV provided feature to swap endianness of a 256 bit variable?
for a 32bit example, the code is less:
assign data_swapped = {{data[07:00]},
{data[15:08]},
{data[23:16]},
{data[31:24]}};
but too much to type in (error prone) for 256 bit.
please advise.
In reply to UVM_learner6:
assign data_swapped = {<<8{data}};
See section 11.4.14 Streaming operators (pack/unpack) in the IEEE 1800-2017 SystemVerilog LRM.
rag123
3
module tb;
int a = 'h12345678;
int b;
b = {<<byte {a}};
$display ("A value is %h",a);
$display ("B value is %h",b);
Hi ,
For 12345678 input ,the output is 78563412 not 87654321.
How to achieve 87654321.
