Duplicate typedef definitions
Let’s say that I have two independent packages, A and B, each of which contain the following line:
typedef bit [7:0] t_dyn_byteArray; // dynamic byte array
If I have 3rd package, C, which imports packages A and B.
The simulator is flagging an error on my very first declaration of type t_dyn_byteArray.
I would prefer not to create a “global” typedefs package which would be important by all 3 packages. Can I keep the original definitions in package A, and B, and still protect C from a typedef “collision”?
package A;
        typedef bit [7:0] t_dyn_byteArray[];
endpackage
package B;
endpackage
package C;
        import A::*;
        import B::*;
         A::t_dyn_byteArray foo;
endpackage
One other piece of unsolicited advise, be careful with your 2 t_dyn_byteArray typedefs, since they are declared independently they are considered 2 separate types, so having a single ‘global’ type may actually be your best bet
In reply to alexgran:
Two other things you can do are:
Similar to Alex’s suggestion, you can explicitly import one of the typedefs so there would be no wildcard conflict
package C;
        import A::*;
        import A::t_dyn_byteArray;
        import B::*;
endpackage
However, I would strongly discourage using the same identifier in two different packages where you intend to import both packages in the same scope. A better solution would be to create a common package and then export the identifers from that common package so that they would be imported as package A or B
package common;
endpackage
package A;
  import common::*;
  export common::t_dyn_byteArray;
 // other A stuff
endpackage
package B;
  import common::*;
 // other B stuff
endpackage
package C;
        import A::*;
        import B::*;
         t_dyn_byteArray foo; // no identifier conflict
endpackage
I reworked my packages and now have a single typedef declaration; works great. Thanks for the good suggestions, Dave and Alex.
The exporting looks like an interesting technique, but I think with my personality it would bite me; I’d forget about the export and then not understand how package C was acquiring a “buried” typedef.
