Difference between onehot() and onehot0()
I have read the difference between onehot and onehot0 on several blogs but I am not sure how they differ because onehot() is only 1 bit out of n bits should be one at any given time which means the rest of the bits are 0. And onehot0() says atmost 1 bit should be high with all remaining values 0.
Please correct me if my understanding is wrong. I’m unable to spot the difference.
Any help is appreciated.
Thanks in advance.
In reply to sk9:
Section 20.9 Bit vector system functions in the IEEE 1800-2017 SystemVerilog LRM answers this:
$onehot ( expression ) returns true (1’b1) if $countbits(expression,'1)**==**1, otherwise it
returns false (1’b0).
$onehot0 ( expression ) returns true (1’b1) if $countbits(expression,'1)**<=**1, otherwise it
In reply to sk9:
$onehot0 is not clear to me. Could you please check this example?
Example : If we have [1:0] state variable,
$onehot will return true for states 2’b01 and 2’b10.
$onehot0 will return true for states 2’b00, 2’b01 and 2’b10.
Is my understanding correct?
Thanks.
In reply to UVM_learner6:
It seems that it is clear to you.
Thank you, Dave.
