I want to use register name in the regmodel hierarchy depends on some define.
When SINGLE_COUNTER is defined as `define SINGLE_COUNTER:
if(m_regmodel_inst.REG1.FIELD.get_mirrored_value()) begin … -
when SINGLE_COUNTER is not defined:
if(m_regmodel_inst.REG1[cntr_no].FIELD.get_mirrored_value()) begin …
Similar way, want to use different registers also.
Can I create macro using define to get the reg name (either "with index" or "without index") ? So that would be easy to replace as below: if(m_regmodel_inst.REG_NAME(REG1, idx).FIELD.get_mirrored_value()) begin
If its possible, how to define `REG_NAME(REG1, idx) ?
Thanks in advance.
