In VHDL I can declare signals as below:
signal cntr : integer range 0 to 31;
So the values of cntr can be any integer value from 0 to 31.
How can I make the same definition and/or workaround in systemverilog?
In reply to moustafaali:
bit [4:0] cntr;
In reply to Jeff Chen:
and what about ?
signal cntr : integer range 0 to 20;
integer cntr;
assert #0 (cntr inside ([0:20]);
if i make increment like “cntr = cntr +1 ;”
the assert syntax give error if cntr exceed the max value.
in the vhdl range syntax the cntr will return to 0 after reach the max value(overflow).
anyway it seems that there is no definition for this operation so i will make it using if statement checking the max value.
thanks for your time.
