Hello, I am learning how to model a datapath and control design in Verilog, and I have taken an example of multiplication through repeated addition.
Following is the output I am getting:
0 x x
35 0 x
45 x x
I have taken two inputs: 17 and 5, it’s output should be 85. Can someone tell me where am I going wrong?
module MUL_datapath(eqz, LdA, LdB, LdP, clrP, decB, data_in, clk);
  input LdA, LdB, LdP, clrP, decB, clk;
  input [15:0] data_in;
  output eqz;
  wire [15:0] X,Y,Z,Bout,Bus;
  PIPO1 A  (X, Bus, LdA, clk);
  PIPO2 P  (Y, Z, LdP, clrP, clk);
  CNTR  B  (Bout, Bus, LdB, decB, clk);
  ADD  AD  (Z, X, Y);
  EQZ COMP (eqz, Bout);
module PIPO1 (dout, din, ld, clk);
  input [15:0] din;
  input ld, clk;
  output reg [15:0] dout;
  always @ (posedge clk)
    if(ld) dout <= din;
module PIPO2 (dout, din, ld, clr, clk);
  input [15:0] din;
  input ld, clr, clk;
    if(clr) dout <= 16'b0;
  	else if(ld) dout <= din;
module ADD (out, in1, in2);
  input [15:0] in1, in2;
  output reg [15:0] out;
  always @ (*)
    out = in1+in2;
module EQZ (eqz, data);
  input[15:0] data;
  output eqz;
  assign eqz = (data==0);
module CNTR (dout, din, ld, dec, clk);
  input [15:0] din;
  input ld, dec, clk;
    if(ld) dout <= din;
  	else if(dec) dout <= dout-1;
module controller (LdA, LdB, LdP, clrP, decB, done, clk, eqz, start);
  input clk, eqz, start;
  output reg LdA, LdB, LdP, clrP, decB, done;
  reg [2:0] state;
  parameter S0 = 3'b000, S1 = 3'b001, S2 = 3'b010, S3 = 3'b011, S4 = 3'b100;
      case(state)
        S0: if(start) state <= S1;
        S1: state <= S2;
        S2: state <= S3;
        S3: #2 if(eqz) state <= S4;
        S4 : state <= S4;
        default: state <= S0;
      endcase
  always @ (state)
      case(state)
        S0: begin #1 LdA=0; LdB=0; LdP=0; clrP=0; decB=0; end
        S1: begin #1 LdA=1; end
        S2: begin #1 LdA=0; LdB=1; clrP=1; end
        S3: begin #1 LdB=0; LdP=1; clrP=0; decB=1; end
        S4: begin #1 done=1; LdB=0; LdP=0; decB=0; end
        default: begin #1 LdA=0; LdB=0; LdP=0; clrP=0; decB=0; end
      endcase
TESTBENCH:
module MUL_test;
  reg [15:0] data_in;
  reg clk, start;
  wire done;
  MUL_datapath DP(eqz, LdA, LdB, LdP, clrP, decB, data_in, clk);
  controller CON (LdA, LdB, LdP, clrP, decB, done, clk, eqz, start);
  initial
      clk=1'b0;
      #3 start = 1'b1;
      #500 $finish;
  always #5 clk=~clk;
  initial
      #17 data_in = 17;
      #10 data_in = 5;
  initial
      $monitor($time, "%d %b", DP.Y, done);
      $dumpfile("mul.vcd"); $dumpvars(0, MUL_test);
